Can't help you with that, but since you're not sure that something is wrong with your AFM/LMM, why not post a question in the "Algemene technische vragen" section of this forum. Maybe somebody has tips or a spare you can try.
You could try simply disconnecting the AFM. If this doesn't cure the problem it can't be the AFM going bad, it must be something else.
Eric
