wie weet hier iets van af??
quote:
Prices and work quoted are for a set of high-flow heads like mine, with guaranteed more than 117cfm (cubic feet per minute) –std flow is around 105cfm. You will also get a printout of intake/exhaust flow, before and after. All prices in Euros.
Large intake valves (46mm, 8mm stems) and 8mm stem exhaust valves: 360
Special bronze valve guides: 96
Oversize intake valve seats: 180
Head machining+milling: 180
Performance valve springs: 150
8mm retainers +collets: 80
Crack/leak test: 180 (see below)
Porting work, heads: 450
Enlarging std runners and plenum throats: 240
Total: 1916 Euros
kan ik waarschijnlijk overal in nederland voor dezelfde prijs ook laten doen?
verstandige tips zijn welkom
[/url]
