Was het maar waar
Das 426 graden Celcius!!!
de specs op internet:
Red Line CV-2 Grease is designed to withstand the extreme temperatures and pressures which occur in high-performance wheel bearings and CV-joints. The excellent high-temperature stability, extreme- pressure protection, and water resistance enables it to out-perform even the best conventional or synthetic greases. Red Line CV-2 Grease can be used in a wide range of applications at temperatures ranging between
-100°F to 500°F and provides good oxidation and corrosion resistance, low evaporation and oil separation, and has a minimum effect on rubber seals. Possesses a very high melting point, excellent water washout resistance and superior antiwear which makes it excellent for high temperatures and extreme loads.
CV-2 contains an organic moly and is for wheel bearings, high angle and conventional CV joints, chassis lubrication and high temperature, high speed industrial equipment. The exceptional extreme- pressure performance and the fluidity of the synthetic oil allows increases in bearing life of 200% to 800%. Red Line CV-2 Grease will retain its consistency and extreme-pressure performance under high- temperature and high-shear conditions for extended periods, which extends the performance ranges of the lubricated components. Red Line CV-2 will darken after high-temperature use; this darkening will not detrimentally effect the performance of the grease. Although Red Line CV-2 is compatible with small amounts of many petroleum-based greases, it is always good lubrication practice to thoroughly clean out the old grease to eliminate abrasive particles and to minimize the possibility of grease incompatibility.
