Bobcore
Camshaft adjustment 1,8turbo
do aug 21, 2008 23:45
Anyone has a good instruction on how to get this right?
Tried to set both camshafts on their marks so they align to the marks on the cam bearing, but then the engine wont run as it should.
Before i tried to adjust, the exhaust cam was a little bit off from the mark, about 1 touth or so.
Also want to know what mark you guys use on the front. P, F or what? After what i can read in the workshop manual i should set the engine to the mark F.
Seen from the flywheel side(behind to front) Should the exhaust be before or after its mark? Same with intake..
Hope anyone can guide me a little her....
RE: Camshaft adjustment 1,8turbo
do aug 21, 2008 23:58
Hi Bob,
P=TDC you need this to adjust your camshafts.
F = about 9 degrees advance for ignition
M= Max advance say 30+ degrees (which a turbo will never reach)
So try to adjust every thing on the P and the camhafts on the marks on the bearing caps.
If you still have problems then, name your camshaftnumbers and post a photo of youre camshaft bearingcap as there are 2 different caps.
They should be exact on time...???
vr aug 22, 2008 00:17
Sow! See that Andretti on ones English speaken zeg!
Bob, trust him! :wink:
vr aug 22, 2008 08:53
It could be that someone tried to move the cams a few degrees to alter the engine characteristics. Also, it could be that non-standard cams were fitted that need other timing. If it was running fine before, don't change the settings until you know what type of cams you are running. Andretti Molletti already asked for the ID numbers on the cams, let's hope they didn't re-grind other cams and left those numbers in. That would make things very confusing.
Brul(tm)
Re: RE: Camshaft adjustment 1,8turbo
vr aug 22, 2008 09:03
:jumping:
Groetjes,
Marc
Alfa 155 Q4
Seat Leon fr
Michel vd Grinten
vr aug 22, 2008 15:16
FO zaagmans :lol: :lol: :lol:
Mag ik dat wat kracht bijzetten, door een ander hilarisch figuur?
Zaagmans: Afbeelding :D:D:D Don't mess with the Dre ;)
vr aug 22, 2008 15:33
NU ga ik me beledigd voelen! :evil: :evil: :evil: :evil: :evil:
vr aug 22, 2008 16:43
FO is een gerespecteerd figuur hier op het forum... Forza Ollanda was ons motto toen we europees reden...
Michel jij rijdt in die gele perenkist he??? :twisted: :twisted:
Bobcore
vr aug 22, 2008 16:56
Thanks guys! I will open up the top later tonight and post a photo..
Forget to say this, but this is a 2,0 with turbo.. Andretti already know this, so i think he know what i mean.
At least one of the cams was out of position.
vr aug 22, 2008 18:49
Then why in heavens name would you name the topic "Camshaft adjustment 1,8turbo" ?
Bobcore
vr aug 22, 2008 18:55
Because Alfa never made a 2,0 turbo except of the Turbo Delta that came with carburettors.
The camshaft adjustment has to be for 1,8l since the volum is 2,0 but everything else is from 1,8l
Camshafts are the same for 2,0 and 1,8.. So, therefor i asked for adjustments for 1,8 since there has never been a 2,0 so people would not understand what i asked for if i wrote 2,0 turbo.
Worst case they would understand it to be a 2,0 V6 turbo.. :)
Michel vd Grinten
vr aug 22, 2008 18:57
:D :shock: FO is anders geinterpreteerd dan ik dacht???
Ja Dre, die Gele perenkist is waar ik mijn derriere in zal planten.....problemen daar mee? ;)
vr aug 22, 2008 19:42
1.8 turbo camshafts are actually different from normally aspirated ones... :wink: The timing marks for the right position of the crank and camshafts are the same however.
Are you using the normal 2.0 pistons and compression?
vr aug 22, 2008 20:03
Hola JIJ interpreteerde dat he ;)
en nu weer allemaal lief en aardig zijn anders ga ik gillen!!! :lol:
The pistons are specially made for the job Remco :wink:
