gtv6_wm
Re: RE: ** Alfa Romeo Miniaturen ** . Neurenberg 2010: Mini
wo feb 24, 2016 01:54
hello,
question is very old, so my answer may confirm / disagree other answers :
this white metal Alfa romeo P3 was made in 1976 in England by Paddy Stanley.
It was released as Paddy Stanly nr 8 and dit not have any decals.
I own this old kit, still in original condition (hope I can find it after all this years)
please let me know if you need more information.
best regards from Belgium,
gtv6_wm
Re: ** Alfa Romeo miniaturen ** . . . Bburago Giulia's
wo feb 24, 2016 02:00
sorry,
my answer does not give reference to the question :
question is from AR110AF
see page 439 of this topic
:oops:
wo feb 24, 2016 09:49
This question:
I have a question maybe someone here can answer.
I recently bought a few old models of the 70s, including this one:
I thought it was John Day, but Day never issued a Tipo B (P3), according to all sources. There's no marking under it, except a painted sign (containing maybe a C) and what appears to be a # 48. It may or may not relate to the manufacturer catalogue number, or any identification making sense for who assembled it.
I'm sure I have a picture of this very model somewhere, but it is definitely not in Rampini nor in the miniature magazine I have, and I failed to find back the pic which is impressed in my memory.
Browsing Fer's listing, the likely candidates might be Classic Cars or Plumbie Inter, as it is white metal and represents a 1934, cart sprung Tipo B (not the Stanley 1935 Dubonnet version, shown in the background).
Anyone owns the same and/or can identify it?
Thanks
Probleem na 6 jaar opgelost, tof gtv6_wm! :thumbs:
AR110AF
wo feb 24, 2016 09:58
Thank you for the confirmation. It was my best guess so far, now confirmed! :thumbs:
** Alfa Romeo miniaturen ** . . . Paddy Stanley
wo feb 24, 2016 10:01
Meer informatie over Paddy Stanley.
Paddy heeft behalve de P3 (oplage 100-200 stuks wit metaal) nóg een Alfa gemaakt, een P2 waarvan een 20-tal in glasvezel en een paar in wit metaal.
AR110AF
Re: ** Alfa Romeo miniaturen ** . . . Paddy Stanley
wo feb 24, 2016 10:15
Hello Hans.
The resin (?) P2 is a model I had the luck to find, and is fascinating indeed for being hollow:
See here for more comparative pictures
Now back to the identification of the P3. I have maybe been too fast 10 min ago with the confirmation: when I bought this P3, I ruled out it as being Stanley (and wrongly agreed here above on the base of my collection file, where I have a Tipo B Stanley listed), as I identified the Stanely as being this other model in my showase:
Consistently with its description, it's a 1935 Dubonnet front suyspension car with wide body. Alfavaganza, on the bottom of page 439, discussed that on the base of the wheels, the "unknown P3" has distinctly different wheels compared to the known Stanley. gtv6-wm, can you please confirm that the wheels in your kit fit those on my model, as well as the features of the car (narrow body, cart sprung, steering rod, etc.) ?
wo feb 24, 2016 11:24
Hello Hans.
It is a mix:
I carved a ‘master’ out of polystyrene sheet which I had cemented into a block and using a one-piece, open, Silastomer mould I cast each body using gel coat, glass fibre ribbon and casting resin – a very laborious process.
A very rare but also extremely interesting model because it's from the earliest days of models produced not as toys but as collector's items.
gtv6_wm
wo feb 24, 2016 13:38
heb de kit "eindelijk" teruggevonden
heeft vooraan inderdaad dubonnet ophanging
het model van AR110AF lijkt echter verdacht veel op mijn kit (misschien is het een transformatie van de Paddy Stanley ?
foto van mijn kit : help , ik kan geen foto toevoegen. te weinig op dit forum gezeten :(
zie daarom dropbox link naar mijn foto:
https://www.dropbox.com/s/fo27j6xhv7ypu ... 8.JPG?dl=0" onclick="window.open(this.href);return false;
wat ik gehoord of gelezen heb over de P2 van Paddy Stanley : gemaakt eind jaren 60 (?) , er zijn slechts enkele stuks van gemaakt in polyester er zijn een drietal stuks van gemaakt in white metal (white metal vermoedelijk begin jaren 70)
AR110AF
wo feb 24, 2016 14:20
Thank you very much. I've looked at your picture, and it fits the model I identified as Paddy Stanley, the one reproduced on this page with bare metal radiator cowling.
The link provided by Hans gives all details on Stanley's "business" back in the 60s-70s, including numbering this P3 as #10 in his production, instead of #8 as reported in Alfa models listings.
This leaves my other WM model of P3 unidentified. After a second check, my "best guess" would be Grand Prix Models, a guess based on the exclusion of other models described with non fitting features. But I might be wrong, and would love to be proved so! 8)
gtv6_wm
wo feb 24, 2016 16:11
Hello AR110AF,
I partly dry-assembled my P3 from GPM (Classic car series nr 76) to allow comparison with your P3.
https://www.dropbox.com/s/ns82cy325kqjz ... 2.JPG?dl=0" onclick="window.open(this.href);return false;
For me it is not clear whether or not they are the same model, they might be.
The tires in the Classic car kit are VERY small (check my dropbox picture included above) and seem to be the same as the one's on your model : wheels are smaller than the brake drums.
The wheels in the Paddy Stanley kit are larger size.
AR110AF
wo feb 24, 2016 16:21
Brilliant! For me there's no doubt that my assembled model is indeed the same as your GPM kit. Everything fits, from the small wheels to the shape of the cowl, the place where the steering rod has to be glued, and the overall rounded shape of the body. Also same louvres on the apron, same front crossmember. No doubt left. Thank you for the confirmation of the identification. :thumbs:
** Alfa Romeo Miniaturen **Hachette edicola>Whitebox
vr feb 26, 2016 12:50
het Italiaans forum Automodellando meldde in maart, dat in Toscane (Arezzo) Hachette een nieuwe edicola serie zou testen. Alfa Romeo Collection die-cast 1:43 uit China, gemaakt bij Leo Models (net als de Fabbri Sport Collection- Metro Model edicola).
eerste model €uro 3.99, daarna €uro 7.99 en vanaf no3 €uro 13.99
uscita 1 Giulia Nuova 1300 Super 1974 blauw
uscita 2 33/2 Stradale 1967 rood
uscita 3 Sud Sprint 1.7 QV 1987 zilvergrijs
uscita 4 8C 2900 Lungo 1937
Een beperkt aantal test exemplaren haalden al snel de Ebay sites. Bij Hachette bleef het stil. Eerst werd verwacht dat deze 1:43 modellen serie in september 2015 zou starten, het lijkt er nu op dat Hachette afziet van deze edicola ?. De gemaakte rest voorraad wordt dan via andere kanalen op de markt gebracht. Deze 4 modellen staan nu aangekondigd bij importeur Replicars in de Whitebox verpakking met een andere prijsstelling. Whitebox is een merknaam van webshop ModelCarWorld voor heruitgaven van niet verkochte oudere kiosk series, soms in andere kleuren. Ook in 1:24 bracht Whitebox al enkele Alfa modellen opnieuw uit, bekend uit de Quattroruote/Hachette/Fabbri edicoli.
Laatst gewijzigd door Alfa Romeo Miniatura Fer op ma nov 06, 2017 14:51, 1 keer totaal gewijzigd.
vr feb 26, 2016 14:21
In Nederland te bestellen bij Automodelli.nl. Ik heb alvast een Giulia Nuova en een Sprintje gereserveerd 8)
Tom
vr feb 26, 2016 21:41
Die Sprint lijkt me voor dat geld erg leuk. Gaat er komen!
Re: ** Alfa Romeo Miniaturen **AlfaModel43 6C2300B
di mar 01, 2016 15:23
Francesco De Stasio is een van de pioniers in 1:43 Alfa Romeo modellen, destijds in witmetaal kits: F.D.S.Automodelli, tegenwoordig gebouwd in resin als AlfaModel43. Ook zijn zonen Giovanni (Jolly Model) en Pasquale (Top Model Collection) zijn actief in Alfa miniaturen.
De Stasio heeft al een uitgebreide serie Alfa 6C 2500 en 8C 2900 modellen uitgebracht. Nieuw is zijn 6C 2300B Touring berlinetta 1935 in vele Mille Miglia en 24 uurs van Pescara uitvoeringen.
AlfaModel43 resin 1:43, in oplage van 100x elk:
AM43 343 6C 2300B Touring Mille Miglia 1935 no100 Cortese-Severi, Scuderia Ferrari, zwart
AM43 344 6C 2300B Touring Mille Miglia 1937 no103 Spegiette-Gambaro, grijs
AM43 345 6C 2300B Touring Mille Miglia 1937 no117 Randaccio, zwart
AM43 346 6C 2300B Touring Mille Miglia 1937 no18 Nicola di Romania-Tadini, grijs
AM43 347 6C 2300B Touring 2# 24u. Pescara 1935 no11 Rosa-Comotti, achter Cortese in no10, zwart
AM43 348 6C 2300B Touring Berlinetta 1935, 2tone crême-bruin
AlfaModel 43/ FDS 1:43 resin cast: Francesco De Stasio vervolgt nu met een serie 4-deurs Touring 6C berlina
AM43 351 6C 2300B Touring 1935 stradale Museo Storico, bruin
AM43 352 6C 2300B Touring 1935 stradale, rood
AM43 353 6C 2300B Touring Mille Miglia 1938 no136, grijs
AM43 354 6C 2300B Touring Mille Miglia 1937 no114, rood
Laatst gewijzigd door Alfa Romeo Miniatura Fer op ma nov 06, 2017 14:52, 1 keer totaal gewijzigd.
