gerommeld of is het gewoon toeval??
Mazda Speed 6-- The Ultimate in Midsize Sedans
I-Newswire
2005-05-18
The Mazdaspeed6 offers the optimal balance between performance and sophistication," said Weldon Munsey, vehicle line manager for Mazda North American Operations ( MNAO ). "The turbocharged engine, with its broad power band, excellent fuel economy and eco-friendly emissions levels, is unmatched in its class, while the sport-minded, luxurious cabin helps deliver a car driver will find hard to exit."
Mazda's own innovative technologies, including the newly developed direct-injection turbocharged 2.3-liter engine with maximum output of an estimated 274 hp and all-new active torque split all-wheel-drive system, make the MazdaSpeed 6 the company's highest performance sedan and push the Mazda brand DNA element of spirited dynamic performance to its ultimate level.
With a 274-horsepower, 280 lb-ft of torque, all-wheel drive, the 2005 Mazda Speed 6 has power from the direct-injection turbocharged 2.3-liter engine channeled to an all-new Active Torque Split All-Wheel Drive system for traction and handling in all conditions.
Exterior highlights include an aerodynamic front bumper and lower grille section, a five-point upper grille section that also serves as the air intake for the engine's intercooler, the flared side skirts. It also includes the custom 18-inch aluminum wheels fitted with 215/45R18 tires, the aerodynamic rear bumper with built-in diffuser for the integrated exhaust tailpipe and a highly effective yet compact rear lip spoiler.
The interior is spacious with high-quality interior materials for a lush finish, custom six-speed shift knob and semi-bucket sport-type front seats for excellent side support.
It packs a turbocharged 2.0-liter 4-cyl engine with direct fuel injection and some 274 hp. A 6-speed manual transmission is mandatory. Also standard are a limited-slip differential, up rated suspension, 18-inch wheels, antilock brakes and antiskid/traction control. To match its performance persona, the MazdaSpeed gets its own front and rear fascias, plus special sport bucket seats and metal-look interior trim. Automatic climate control and 200-watt Bose CD stereo are also included in the package.
A new six-speed manual directs the engine's efforts to both axles via standard all-wheel drive with three torque-apportioning strategies: normal, sport, and snow. Standard equipment includes the 270-horse turbo engine, the manual transmission, and Mazda's new Active Torque-Split AWD system, which can send up to 50 percent of the engine's power to the rear wheels.
The 2005 Mazda Speed 6 has direct injection to a turbo application. Injecting fuel directly into the combustion chamber increases both fuel mixture loading efficiency and torque. As a result, the turbocharger delivers much of its 15.6 psi of boost from approximately 2500 rpm. The single-scroll turbocharger maintains exhaust temperature, allowing for reduced thermal capacity of the exhaust system, which, in turn, minimizes harmful emissions and allows the MAZDASPEED6 to meet both LEV-II state and Bin 5-A Federal regulations.
Whether you choose the muscular refinement of the MAZDA6 Sports Sedan, the well-executed mix of spaciousness and assertive style of the MAZDA6 5-Door, or the utility and sophistication of the MAZDA6 Sport Wagon, Partstrain gives you the finest Mazda Replacement and Performance Parts unmatched anywhere else.
