Is het afvullen gelijk aan de 75. dus bijvullen totdat de olie uit de plug begint te lopen?
Wederom thanks!
Ciao!
not sure baout 147 but a 156 uses 75w/90 synth oil
the fill/drain bungs are 12mm hex headed.
the filler is on the front near the rev switch.
the drain is down beside the subframe, quite hard to get at.
i use a 12mm 1/2" drive, which ive shortened by 2mm & then use a 12mm ring spanner to open this bung.
you may want to consider removing the side cover & then removing 'swarf' build up within that cover
