Camshaft adjustment 1,8turbo
Geplaatst: do aug 21, 2008 23:45
door Bobcore
Anyone has a good instruction on how to get this right?
Tried to set both camshafts on their marks so they align to the marks on the cam bearing, but then the engine wont run as it should.
Before i tried to adjust, the exhaust cam was a little bit off from the mark, about 1 touth or so.
Also want to know what mark you guys use on the front. P, F or what? After what i can read in the workshop manual i should set the engine to the mark F.
Seen from the flywheel side(behind to front) Should the exhaust be before or after its mark? Same with intake..
Hope anyone can guide me a little her....
RE: Camshaft adjustment 1,8turbo
Geplaatst: do aug 21, 2008 23:58
door Andretti Molletti
Hi Bob,
P=TDC you need this to adjust your camshafts.
F = about 9 degrees advance for ignition
M= Max advance say 30+ degrees (which a turbo will never reach)
So try to adjust every thing on the P and the camhafts on the marks on the bearing caps.
If you still have problems then, name your camshaftnumbers and post a photo of youre camshaft bearingcap as there are 2 different caps.
They should be exact on time...???
Geplaatst: vr aug 22, 2008 00:17
door Zaagauto
Sow! See that Andretti on ones English speaken zeg!
Bob, trust him!
Geplaatst: vr aug 22, 2008 01:23
Geplaatst: vr aug 22, 2008 08:53
door WhizzMan
It could be that someone tried to move the cams a few degrees to alter the engine characteristics. Also, it could be that non-standard cams were fitted that need other timing. If it was running fine before, don't change the settings until you know what type of cams you are running. Andretti Molletti already asked for the ID numbers on the cams, let's hope they didn't re-grind other cams and left those numbers in. That would make things very confusing.
Re: RE: Camshaft adjustment 1,8turbo
Geplaatst: vr aug 22, 2008 09:03
door Brul(tm)
Groetjes,
Marc
Geplaatst: vr aug 22, 2008 15:16
door Michel vd Grinten
Mag ik dat wat kracht bijzetten, door een ander hilarisch figuur?
Zaagmans:
:D:D Don't mess with the Dre
Geplaatst: vr aug 22, 2008 15:33
door Zaagauto
Geplaatst: vr aug 22, 2008 16:43
FO is een gerespecteerd figuur hier op het forum... Forza Ollanda was ons motto toen we europees reden...
Michel jij rijdt in die gele perenkist he???
Geplaatst: vr aug 22, 2008 16:56
door Bobcore
Thanks guys! I will open up the top later tonight and post a photo..
Forget to say this, but this is a 2,0 with turbo.. Andretti already know this, so i think he know what i mean.
At least one of the cams was out of position.
Geplaatst: vr aug 22, 2008 18:49
door WhizzMan
Then why in heavens name would you name the topic "Camshaft adjustment 1,8turbo" ?
Geplaatst: vr aug 22, 2008 18:55
door Bobcore
Because Alfa never made a 2,0 turbo except of the Turbo Delta that came with carburettors.
The camshaft adjustment has to be for 1,8l since the volum is 2,0 but everything else is from 1,8l
Camshafts are the same for 2,0 and 1,8.. So, therefor i asked for adjustments for 1,8 since there has never been a 2,0 so people would not understand what i asked for if i wrote 2,0 turbo.
Worst case they would understand it to be a 2,0 V6 turbo..
Geplaatst: vr aug 22, 2008 18:57
FO is anders geinterpreteerd dan ik dacht???
Ja Dre, die Gele perenkist is waar ik mijn derriere in zal planten.....problemen daar mee?
Geplaatst: vr aug 22, 2008 19:42
door giuliettaevo
1.8 turbo camshafts are actually different from normally aspirated ones...
The timing marks for the right position of the crank and camshafts are the same however.
Are you using the normal 2.0 pistons and compression?
Geplaatst: vr aug 22, 2008 20:03
Hola JIJ interpreteerde dat he
en nu weer allemaal lief en aardig zijn anders ga ik gillen!!!
The pistons are specially made for the job Remco
