Simultaanieläin
New alfista with a transmission chain question
di mar 04, 2008 22:03
Hello everybody,
I hope you can read and answer in English (it seems virtually all Dutch and Flamish people can).
I am a Finn living and working in Brussels. I came to ask for help to your forum, since there does not seem to be much going on on the Belgian one.
I am planning to buy an Alfa Romeo 166 2.0 V6 turbo. I am a bit confused with how often transmission chains are changed in Benelux. In Finland, because of the hard weather conditions, they seem to be changed twice as often. The Alfa I am planning has a mileage of 89000 and the transmission chain has not yet been changed. I was told that it is changed at 100000 km. I just thought it would be changed either at 100000 km OR every five years. Since the car is of year 2000, can I drive peacefully still 11000 km or should I immediately have it changed.
There were a lot of broken transmission chains of 2.0 TS engines in Finland, until the rule was changed to 60000/3 years. That's why I am little worried allthough I have heard that transmission chain of the V6 12 valves engines should be much stronger.
Graffiaturo
RE: New alfista with a transmission chain question
di mar 04, 2008 22:06
if you have doubts about the timingbelt, don't wait, just change it ASAP
i thought 60.000km or 3 years they should be changed anyway
di mar 04, 2008 22:08
First a warm welcome to our fantastic site!!
I like finn's and belgiums very much so I will try to answer your question.
(excuse me for my poor english :oops: )
What do you mean by Transmission chain?? Did you mean the distribution of the engine??
Somethimes this mistake is made frequentlier.
So I hope you can explain us more about your transmission chain....and maybe we can welcome you as a SCARB member sometimes :D
Simultaanieläin
di mar 04, 2008 22:13
Sorry everybody!
Not transmission chain, it's called distribution chain. Sorry for my English...
di mar 04, 2008 22:17
Then it is as Graffie said a distribution BELT, no chain ;)
And his answer is the one for the fridge
(this is a joke and means that his answer is the good one!!)
zo goed jongens???
di mar 04, 2008 22:20
Looks like your answer has arrived, so:
chopmax
di mar 04, 2008 22:23
Without insight in the driving habits of the previous owner, I wouldn`t gamble. Change it near to immidiatly.
33 Zwart 1.7 8v, olieboot
33 Rood 1.7 16v, van de sloop gered.
33 Groen 1.4 8v, To do: Voorruit, distributie, grote beurt.
Project:?? Mistery car.
Re: RE: New alfista with a transmission chain question
di mar 04, 2008 22:30
Yep! And, while replacing the belt also renew the belt tensioner and further pulleys, just in case.... :?
Ps welcome btw! :wink:
di mar 04, 2008 22:34
Coolant pump & thermostat as well while you're at it?
Simultaanieläin
di mar 04, 2008 22:48
Warm thanks for answers and welcomes.
Ok, I will drive it directly to the entretien. It seems to be swallowing money right from the beginning. But it's ok, the car costs me nearly half the price it would cost in Finland.
I will try to take soem photographs and insert to the forum somehow, if it's possible.
What do you think it will cost to have those gadgets changed?
giulia-tom
di mar 04, 2008 23:49
Welcome!
PB-message sent! :wink:
nr: 2714
ALFACENTRO
Simultaanieläin
zo mar 09, 2008 11:51
HI again,
I would have one more question about my Alfa 166 2.0 V6 turbo that I bought from Belgium. I went to have a look at what corresponding models cost in Finland. I then saw an announcement with a car like mine (model from year 2000, mileage about 90.000). That car had just had its transmission and clutch repaired because they had got broken. and it had even cost 7000 to repair, so I got a little scared. Does somebody know this model of Alfa better? Is it often that such things happen or did the Finnish guy more probably just have bad luck?
Both cars, mine and the bad luck one, have had just one owner before, who has had all the services done according to rules (every 20.000 km), so it should not be a case of bad maintenance.
giulia-tom
zo mar 09, 2008 12:04
7K to repair? :wink: Maybe I should consider opening in Belgium... :lol: To my opinion there are no official known problems with the gearbox - not more often then other Alfa fwd models.
However it CAN illustrate something about the driving skills of the previous owner? :-k
nr: 2714
ALFACENTRO
cmva
zo mar 09, 2008 12:09
Niet? Verkoop toch wel gemiddeld 2 166bakken per maand.
Ed
giulia-tom
zo mar 09, 2008 12:27
Ik verkoop veel 155 bakken....dus best wel in de lijn.... (PB komt eraan)
nr: 2714
ALFACENTRO
