gtv 105.21
hoogcompresie zuigers waar?
za feb 12, 2005 13:07
hallo allemaal
ik zoek voor mijn 105.21 motor zuigers met een compressie van 11/1 en dan ook nog het liefst 85mm.
waar zijn die te koop.
:twisted:
lid nr 00670
Bartman
RE: hoogcompresie zuigers waar?
za feb 12, 2005 14:00
za feb 12, 2005 14:56
dus gewoon gesmede zuigers. Paul Spruell kan zo ongeveer laten maken wat je wilt, maar ik denk dat dat bij iedereen kan die JE zuigers levert. Misschien dat Cosworth ze ook maakt??
Bartman
za feb 12, 2005 15:09
http://www.paulspruell.com/motorsport/r ... parts.html
JE FORGED PISTONS
$585 Set
25% Lighter than Stock!
LIST PRICE; $828 set of four, includes standard pins (110 gr./ .150 wall), standard rings and wire locks. RACER NET $585. Super light pins (79 gr/.100" wall), $60 extra. TOTAL SEAL RINGS, $114 extra.
We sell single pistons and pins if you damage one and need a spare. We stock spare ring sets, but unfortunately can not break sets to sell singles.
GENERAL NOTES. I have proven on the dyno that our designs on the JE billets make more power. We have been working with the people at JE on our pistons since 1978 and have yet to see a documented piston related failure. My friends in the Winston Cup engine business turned me on to them and I have never strayed. Through our racing engine research and on track experience we have continuously modified the designs for better performance and ease of installation. We welcome customer input and have made a number of changes by popular request. We were listening and now use exclusively wire locks instead of spiralocks. Very recently we offered the 75 & 85mm pistons in two different dome configurations: one for standard heads and light milling and another where severe milling cuts have created interference or lower compression is desired. We won three SCCA E-PRODUCTION National Championships using the same 81mm pistons you can now buy off our shelf. All of the professional Alfa engine builders use our JE design pistons. If you are not a pro, then you will enjoy following our three page set of instructions that come with each set. If you encounter problems or have questions, I am happy to help you over the phone at any time.
ALFA SPECIAL APPLICATIONS
BORE COMPRESSION ENGINE
75mm 12.5:1 1300cc G&P-Production SCCA
75mm 12.0:1 1300 Big Valve
77mm 10.5 1300 Big Bore to 1400cc
79mm 11.5 1600 F-Production SCCA
79mm 11.0 1600 Big Valve & GTA
81mm 11.0 1600 Big Valve/Big Bore 1700
81mm 11.0 1600/1750 Big Valve & GTA
81mm 11.5 1750 E-Production
84mm 7.5 2000 Turbo
84mm 10.5 2000 Motronic Dome
84mm 12.0 2000 Big Valve
85mm 12.5 2000 Big Valve
85mm 10.5 2000 Motronic Dome
85mm 10.5 2000 Twin Spark 3.0L V-6
89mm 10.0 2.5L V-6 ($878 per set)
93mm 10.5 3.0L V-6 ($878 per set)
AVAILABLE WITH:
STANDARD -- DEVES RINGS (included)
UPGRADE -- TOTAL SEAL GAPLESS
RING SET $114 ($175 V-6)
STANDARD -- .150 Wall Pin (98 g)
UPGRADE -- .100 Wall Pin (70 g) - $60 ($90 V6)
LINERS
85MM New $125 each, special cast iron material.
81MM New $125 each, special cast iron material
79MM Rebored, $500 per set - Closeout - no Exchange
gtv 105.21
za feb 12, 2005 19:18
klopt maar probeer bij paul spruell maar eens wat te kopen.
ben nu bijna twee maanden bezig maar lukt maar niet om een totaal bedrag te krijgen en dat vind ik persoonlijk nog al lastig betalen. :x
als iemand hier een andere ervaring me heeft hoor ik het graag.
:twisted:
lid nr 00670
gtv 105.21
za feb 12, 2005 19:21
vv
om bij cosworth zuigers te laten maken is geen probleem, moet je der 24 laten maken en kosten dan ongeveer 130 pond per stuk met pistonpennen en zuigerveren maar geen bussen.
dus het maken is het probleem niet alleen het aantal. :cry:
:twisted:
lid nr 00670
za feb 12, 2005 19:22
Mijn vorige bestelling was er met een week na mijn definitieve order.Altijd ook netjes prijsopgave, korting als actief racer (nou ja actief...) en ook snelle antwoorden op vragen.
Heb net gisteren weer een order geplaatst, ik laat wel weten hoe of wat..
Remco S
za feb 12, 2005 23:59
Volgens mij verkoopt arese classico ook hoge compresiezuigers
gtv 105.21
zo feb 13, 2005 09:46
vv of de duvel der mee speeld ik heb net een rekening gehad.
dus iets voor mijn beurd gepraat. :oops:
:twisted:
lid nr 00670
