performatek kan ook leveren : hier mail die ik retour kreeg van
andykress@performatek.com
Hi Peter, yes i can get some. as you mentioned, i do not normally inventory them, but can order in.
to be honest, i have been getting so much business from europe that i have been thinking about expanding to include alfas that were not sold here.
kind of slim offerings, but am checking to see if there are more.
156,155 & Spider/GTV - i can only get front sway bar mounts in 22, 23, 27 & 30mm
147 - front sway bar mount (22,23,24mm bar), front upper control arm, inner
145,146 - front sway bar mount (22, 23, 27 & 30mm), front control arm, lower, F&R
33 & Sud - front sway bar 14mm; front sway bar for 1.7Q; front sway bar to lower control arm for 1.7Q; front lower control arm - inner; front radius arm, front or rear; steering rack inner tie rod bush; rear trailing arm, sedan only.
i think, am trying to confirm, early spider/GTV & 155 share same bushings for front lower control arm...
andy
Misschien komt't van pas
