GiuliaCorse
Het beste tuning idee in tijden
di nov 13, 2007 15:35
Ok ik heb het eerlijk gestolen van het 156 forum, maar dit is geweldig vooral de reacties.
http://www.gmmodernmuscle.com/forums/vi ... sc&start=0
Laatst gewijzigd door GiuliaCorse op di nov 13, 2007 16:02, 1 keer totaal gewijzigd.
2000GTV TS 1972
Spider 916 1998
Fiorenzato Ducale compact
Richard75
Re: Het beste tuning idee in tijden
di nov 13, 2007 15:36
phpBB : Critical Error
Could not connect to the database
de link doet het niet :)
AlfaFever
RE: Het beste tuning idee in tijden
di nov 13, 2007 15:37
Euh,
Edit: was al gezien.... zal sneller leren typen :wink:
GiuliaCorse
di nov 13, 2007 15:45
Zat er al in, ze hadden in eens meer dan 100000 pageviews in een uur tijd. Zou zeggen probeer later nog eens, ben zelf ook maar tot pag 3 gekomen. :lol:
2000GTV TS 1972
Spider 916 1998
elio
di nov 13, 2007 15:48
First off, Jay, stay out of this.
Ok. I didn't want to mention it but I was thinking about turbo charging my Vette. I got to thinking about it and how in efficient even turbos are (compressor efficiencies of about 80% at best).
Since a turbo's function is to pressurize incoming air and force it into the upper motor, and turbos are driven by high pressure exhaust gas created from the combustion process, couldn't I just bypass the turbo altogether and route my headers back into the throttle bodies?
Since I have CFI, I could balance the DEI (direct exhaust injection as I just coined it) by feeding one header into each throttle body. Yes, the charge air wouldn’t be that cold, but it would be under a hell of a lot more pressure.
I attached a quick sketch below:
There are still a few things I need to work out:
1) How do I get the CFI aircleaner to fit in a way that hides this plumbing?
2) Does anyone make a V-band clamp that will bolt an exhaust header to a CFI throttle body?
3) What pinion angle should I use in my rear-end? I’m sure there will be a noticeable difference in torque output.
What do you guys think?
Michel
di nov 13, 2007 15:52
Geweldig !!!
Ze tunen ook geiten, heb ik de indruk :biggrin:
Alfa155
di nov 13, 2007 16:19
Roeltje 164
di nov 13, 2007 16:37
Ze zijn ook echtaardig voor mekaar daarzo.... :roll: :-#
di nov 13, 2007 16:53
Deze gast heeft of een gruwelijke plaat voor z'n kop of is een ontzettend getalenteerde trol. In beide gevallen is het in ieder geval erg vermakelijk leesvoer. :D
Speeder
Re: RE: Het beste tuning idee in tijden
di nov 13, 2007 17:06
Dacht ik ook al ja, de post is natuurlijk op zun minst triest te noemen. Het is wel duidelijk dat de persoon in kwestie geen (lees uitermate weinig) autotechnische kennis heeft...maar om iemand dan zo af te branden... :lol:
chopmax
di nov 13, 2007 18:13
Dit is toch de functie van je EGR klep? :shock:
33 Zwart 1.7 8v, olieboot
33 Rood 1.7 16v, van de sloop gered.
33 Groen 1.4 8v, To do: Voorruit, distributie, grote beurt.
Project:?? Mistery car.
pb2k
di nov 13, 2007 18:45
ja ik heb ook van die tuning ideeen die ik graag wil delen voor ik ze uitvoer
hier dacht ik net tijdens de terugrit aan, want waarom van die moeilijk kleine switches voor de ruitenwisser en blower als het ook praktisch kan !!
Jens Hoorn
di nov 13, 2007 19:50
Niet helemaal zo overdreven, maar wel ongeveer inderdaad. Er komt een klein deel van de uitlaatgassen idd weer terug in de verbrandingskamer. Milieuvriendelijker, zeggen ze :?
''Drive tastefully''
vjete
di nov 13, 2007 21:14
maar door de warme uitlaat gassen heb je minder vermogen en ga je uiteindelijk meer gas geven om hetzelfde vermogen te hebben en dan verbruik je juist meer :wink:
zo heeft MAN het ook bedacht bij nu nieuwe motoren en het gevolg was dus minder vermogen en uiteindelijk meer verbruiken
dan doe je eens iets voor het milieu :)
di nov 13, 2007 21:15
Ja ho eens even, EGR wordt door de ECU geregeld en onder vollast gaat er heus geen inert gas de motor in.
