AR 2.0 TS torretje met 275 PK
Geplaatst: wo mar 24, 2010 19:58
Tuuuuuuuuuuuuuuuuuuuurlijk...
complete engine 275 hp with magneti ecu.
The engine had full rebuild (except the block cyl) before the last
event (the oil pump, 2 new Cat Cams, springs and valves were new) and it as run 4h since.
The rods are carillo and the live time bolts are new (60 € each).
The crank is treated.
The bloc cyl and the pistons have 1 saison and the engine was starting to
use 1L oil for 1h1/2 race.)
A new block is included in the price( the only part needed for a rebuild is a set of wossner pistons 800€).
The price include the complete engine with the flying wheel ,4 individual throttles bodies 48mm +
2air boxes + 2 new spares air boxes with 3KN air filters.
Spare engine loom + dyno loom also included in the price.
Many parts avaibles from the car see on the web site www.mpmototsport.be
Dyno-uitdraaitje voorhanden?
hiero
hiero
