di apr 04, 2023 22:18
"1. Tyres manufactured before 2000 – A three digit code was used, which stated the week of the decade it was manufactured. For example a code of 148 means the tyre was manufactured in the 14th week of the 8th year of the decade. This code assumed that a tyre would not be in service for more than a decade so you know that it was made in the 8th year of the decade, but it does not state which decade that was. So in our example the year may have been 1968 or 1978 or 1998 etc. A key point here is that it is recommended that a tyre should be replaced after 6 years no matter how much it has been used. So you are best to steer clear of buying tyres which were manufactured before then."
Na 2000: XXYY XXproductieweek YYjaar in dit milennium
Dan zijn dit vast radiaal banden uit 1948 toen michelin ze uitvond dat verklaart meteen de vraagprijs en de aluminium tuinslanghouders krijg je er gratis bij.
