AR110AF
RE: ** Alfa Romeo Miniaturen ** . . . centenarialia
zo mar 21, 2010 16:28
I have taken a few more pictures of the windows of that Giulietta SS Provence Moulage (click on them to enlarge)
Checking closely to refresh my memory, I have found out that only the rear window was the vacuformed glass provided with the kit, while I had been able to build a scratch windscreen from a plain clear plasticard sheet, bent and adjusted to the model. The advantage of that time consuming technique is that not only you can achieve the best fit, but also get a cristal clear window, where vacuformed glasses are less transparent.
All glasses are glued with instant glue, a minimal amount in order to avoid the white clouds their gases cause, and exclusively on the very edge of the glass. I start on one side, and go on all around. It needs to be fitted perfectly straight at the beginning!
On the driver's side, where I started, the fit is perfect.
But in this case, I came one or two tenth short on the passenger side. Since everything else was perfect, I didn't strip and redo everything. Instead, i filled the gap with a wood glue that becomes transparent when dry.
A tiny trace of instant glue can be seen, with such an enlargement of the picture (remeber: 1/43!) on the lower front edge of the side window, despite the photoetched frame should have kept it hidden.
The rear window was instead, as I remembered well, the vacuformed one provided by Provence, which proved large enough to be cut exactly to the opening size, and glued in place sthe same way as the windscreen.
Note how vision through vacuformed window is less clear than through cold-formed sheet of clear plastic as the other windows of the model.
Some wear on the silver painted chrome frame is the result of taking the model in hands once over time since 20 years. Should be restored, but remeber that the red paint surfacing there are spots large one tenth of mm. maximum in real size...
:blue_cool:
Alfissimo
zo mar 21, 2010 20:56
Aangezien mijn Sei van Norev 1 wieltje te kort had: van
naar: Afbeelding
Heb de randjes er wel niet opgedaan want tis toch wel een heel erg precisiewerkje en niet meteen mijn sterkste punt maar ben toch heel blij met het resultaat :-)
SCARB 6276
'72 Giulia Super 1.3
'82 Alfasud 1.5 Ti
'84 Alfasud Sprint 1.5 Qv
'88 Spider 2.0 Quadrifoglio
'92 Spider 2.0 USA
'94 155 1.7 TS
Re: RE: ** Alfa Romeo Miniaturen ** . . . centenarialia
ma mar 22, 2010 10:26
Amazing, simply amazing! How did you get it rounded so well? Was this done when fitting it in the body, or before?
ma mar 22, 2010 10:33
Ziet er netjes uit hoor. Wat voor randjes hadden er dan nog bij gemoeten?
Corrado
ma mar 22, 2010 11:09
Randjes rond de ramen, schat ik in...
Koen
Laatst gewijzigd door Corrado op ma mar 22, 2010 15:37, 1 keer totaal gewijzigd.
AR110AF
ma mar 22, 2010 12:13
Hey, now you can figure out why it took me 120 hours for the 75. ](*,) , and I ended wondering about my mental health... 8-[
The clear sheet was adjusted with sandpaper until I obtained the exact shape and size, even giving some bias to the edge so that the external side of it would fit, i.e. tappered internally.
Alfissimo
ma mar 22, 2010 20:16
die met de schroefjes. maar was echt te moeilijk, eerste gelijk krom geduwd dus heb ze er maar afgelaten staat ook mooi
SCARB 6276
'82 Alfasud 1.5 Ti
'92 Spider 2.0 USA
'94 155 1.7 TS
za mar 27, 2010 05:49
Tecnomodel is bezig met de eerder aangekondigde alfa modellen.
Hier staan de te verwachten modellen met hun prijs. ($299/stuk)
http://www.tecnomodelcars.com/webstore/ ... ex&cPath=4
alfasudjoe
za mar 27, 2010 11:45
[quote = "Kitaro"] Tecnomodel is working with the previously announced alpha models.
Here are the models and their expected price. ($ 299/stuk)
Ciao Kitaro,
these models will be worth looking forward too i wonder what the similarities will be in quality to Spark models ?
How is your collection of alfa 155`s coming on ??
Saluti
Joe
za mar 27, 2010 17:34
@Joe.
Waiting for new 155 models to apear, i have most other ones. :wink:
Just bought a ABC Brianza 500 transporter 1:43. And the two TZ2's from the auction are late. I should get them next week.
za mar 27, 2010 20:34
Eindelijk weer eens een kitje afgebouwd. De 6c 2500 S Coupé Pininfarina 1950 van Klaxon:
alfasudjoe
za mar 27, 2010 23:11
@Joe.
Ciao Kitaro,
Do you have any of the older BBR built 155`s ???
Saluti
Joe
zo mar 28, 2010 05:16
Joe i got BG 17,18,19,34,38,39,41,42
I might have AR4, but it could be a build PJ25. I have my doubts.
Although it realy looks like a factory build. (Box, nameplate.) But the build quality is not up to par with the other factory builds i have.
Do you know if the ARxx range is a kit or a build range with BBR?
Corrado
zo mar 28, 2010 16:37
Ziet er mooi clean en strak uit Michiel! :shock:
Koen
alfasudjoe
zo mar 28, 2010 20:31
[quote = "Kitaro"] i got Joe BG 17,18,19,34,38,39,41,42
Although it really looks like a factory build. (Box, name plate.) But the build quality is not up to par with the other factory builds i have.
Do you know if the ARxx range is a kit or build a range with BBR [/ quote]
Ciao Kitaro,
I always thought the AR Range kit form were i maybe wrong?
Regards
Giuseppe
