Mooi (transaxle) race spul
Geplaatst: di nov 16, 2010 20:18
door Paulo
RE: Mooi (transaxle) race spul
Geplaatst: di nov 16, 2010 20:38
door Carbo
Iemand ervaringen met dit bedrijf?
Gr,
Carbo
Geplaatst: di nov 16, 2010 20:54
door giuliettaevo
Ziet er een beetje "buiten-budget" uit helaas...
Wel leuke plaatjes die ik langs zie komen van die oranje GTV
Geplaatst: di nov 16, 2010 20:55
door Performa
Damn daar staat mooi spul op die site maar ziet er idd duur uit.
Geplaatst: di nov 16, 2010 21:16
door Paulo
De eigenaar van het bedrijf schreef me dit:
The adjustable dedion axle is build to customer order.
It features camber and toe in/out adjustment and a lightweight dedion triangle
We have build versions for the homologated (Alfa 75 Turbo Evo) 300mm vented discs and a 4 pot calliper (alcon) as well as versions without brakes.
Also the dampers make an influence (eye or stud mounting)
But please notice that no brakes are included – some racers have already a brake setup so we would need them to get those fitted to the axle if possible.
As well as the dampers and one wheel.
Also the wheel(tire) size and ride height is important for the wattslinkage center mount (rollcenter location).
Some measurements must be taken by the customer e.g. trackwide..
You´ll see that in case of interest we must discuss some construction variations
As an example I´ll give you the price for customers (enterprices of trade and commerce will get a discount) for the alcon setup and a eye mounting type damper
Pricing is 6250,- Euros plus 20%VAT
At the time of order 50% payment in advance should be made
Final payment before postage
Delivery time approx. 8 weeks
If the provided parts for building are send to us a further discount is made
Those parts would be:
One original Alfa 75 rear axle with drive shaft flanges and 4 or 5 stud hub
2 new rear wheels bearings
1 dedion center bearing like the ones from Ron Simons
So that’s it.
Geplaatst: vr nov 19, 2010 19:17
door JP6
Doe mij maar zo'n achterasje voor Sinterklaas.
Geplaatst: wo dec 08, 2010 13:39
door vV
en? paste het in de schoorsteen?
Geplaatst: wo dec 08, 2010 18:54
door JP6
Helaas, stout geweest dit jaar zeker.
Zat geen achteras in m'n schoen.
Hum, beste kerstman ..............
Walter heb je mijn mailtje over H.A.N.S. wel ontvangen?
Geplaatst: wo dec 08, 2010 22:31
door vV
ja heb ik ontvangen Jon, je krijgt zo antwoord! sorry, beetje gekkenhuis hier...
Geplaatst: zo dec 19, 2010 10:09
door B-lee
Heeft iemand de GTV van prototech al zien rijden ?
Geplaatst: di dec 28, 2010 15:01
door alfaqv75
gaaf, dan een 3ltr 24V in het vooronder die je hier kan halen:
http://www.beninca.com.au
Dat geeft wel een leuk resultaat: This example shows the multi throttle set up on a 24Valve Alfa Romeo engine being prepared for some testing on the engine dyno. 400 HP at 7300RPM
